While on break I started my car to listen to the radio and keep warm. After 10 minutes, it cut off. I checked the fuel pump to see that it is working. I check the spark plugs and found no electricity was flowing. I cleaned under the distributor cap and replaced the rotor. Still it won’t start.
Check your fuses and the main relay. Then check the condenser. Check coil and then the Crank sensor and camshaft sensor. Then the PCM. Use the wiring diagrams below to help trace the issue.
Engine Controls Wiring Diagram 1996 Mazda 626
1996-mazda-626-engine-controls-a-t-1-of-2 1996-mazda-626-engine-controls-a-t-2-of-2
