Home » Car Questions » 2001 ford f150
2001 ford f150
2001 Ford F150I have access to a 2004 v6 engine. Will that fit into a 2001 ford f150 that i need a new engine for.?
Yes. The 4.2L engine (Long Block) will fit your 2001 Ford F-150. You may need to change over some of the components and wiring harness if you are going to try and use all the sensors, etc. If you stick with just the long block you shouldn’t have any issues.
Tenth Generation Ford F-150: 1997-2003
Eleventh Generation Ford F150: 2004-2008
