Car hardly moves on take off you have to press pedal to floor to get it to barely move, once it gets going drives fine. Until you have to slow below 15 mph. If you try to take off with car in 2nd. its a little better but u can tell car is working really hard. Any suggestions on what could be happening?
My first guess would be some sort of transmission issue. If the engine is revving but the car isn’t going any where, most likely reason would be low on transmission fluid. However, there is a chance you are driving with the park brake on or one of your brake calipers is sticking.
