quits running while driving but starts back. Could it be the crankshaft position sensor?
This could be from a loose electrical connection. This could be from a faulty or failing engine sensor. Or could be from a failing ignition control module. The most common for this engine would be the crankshaft position sensor.
Crankshaft Position Sensor Replacement 2002 Saturn Vue 2.2L engine
- Disconnect the negative battery cable.
• | Engine Harness Connection (1) |
• | Battery Feed (2) |
• | Starter Motor (3) |
• | Starter Solenoid (4) |
- Raise the vehicle.
- Remove the 2 starter solenoid harness connector attachment nuts.
- Remove the lower starter assembly to the engine block bolt.
- Remove the upper starter assembly to the engine block bolt.
- Move the starter right to clear the engine block, then left to remove the starter from the flywheel housing.
- Disconnect the CKP Sensor harness connector.
- Remove the CKP sensor attachment bolt and remove the CKP sensor.
