Where is the timing sensor at and I’m getting gas in the oil?
The timing sensor is known as the Crankshaft Position Sensor. (See Engine Sensors). The Crankshaft position sensor location is behind the harmonic balancer in the timing chain cover at the bottom. As for gas in the oil, look for a foiled spark plug or a sticking fuel injector that may be leaking.
Crankshaft Position Sensor Location and Replacement 1995 GMC Jimmy
Removal Procedure
- Remove the electrical connector.
- Remove the sensor hold down bolt.
- Remove the sensor from the timing cover.
Important
- Inspect the sensor 0-ring for wear, cracks or leakage.
Replace if necessary. Lube the new o-ring with clean engine oil before installing.
Installation Procedure
Important
- Install the sensor into the timing cover.
- Install the sensor hold down bolt.
Tighten
Tighten the hold down bolt to 8 N·m (71 lb in).
Caution! Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
- Install the electrical connector.
