Home » Car Questions » 1996 Suzuki x-90 5 spd 4×4
1996 Suzuki X90My clutch pedal keeps shearing, Do I need to replace clutch? and, it was towed from the front, when putting transfer case in neutral, rear wheels are still engaged, had to tow in 2wheel drive,, Then found out it was supposed to be towed from the rear!,, What happened to the transfer case ? why wont it go into neutral?
Hard to tell without taking it apart and seeing what is broken. This is just one of those things that doesn’t happen that often. Not common enough to be able to make a significant guess. Tearing into it is going to be required for this one.
