My Pathfinder will not restart after it has been running and shut off. I have replaced distributor, rotor, map, pcv. When it runs it idles good but after it gets warm and I try to restart it will not turn over.
If it is the engine not turning over to start, the problem would be the starter assembly. Replace the starter and it should be fine once more. The internal brushes become worn and no longer make good contact. The only other thing could be a bad battery.
