Home » Car Questions » Fusible Links 2003 Ford Taurus SES
2003 Ford TarusWhere are the fusible links located on this vehicle.
Fusible Links are generally located along the battery cables. The cables that connect between the battery and the alternator are widely used on many vehicles. When the links fail the entire section needs to be replaced. The 2003 Ford Taurus does not have any. Instead it utilizes a large 174 amp fuse that is located in the Battery Junction Box.
fusible links
Fusible Links – Power Distribution 2003 Ford Taurus
What is a Fusible Link?
A fusible link is a short piece of insulated low-voltage cable within an automotive wiring harness. It is there to protect the harness where a fuse is unsuitable. In an extreme current overload situation, the conductor within the link is melted while the excessive heat is contained within the link’s insulation.
