There is no top transmission mounts, you are correct about that. There are two engine mounts and one transmission mount. It is normal for the transmission to want to lower. You should place something under it to support it when removing the skid plate.
The transmission and transfer case crossmember is integrated with the transfer case skid plate.
WARNING: THE TRANSFER CASE AND TRANSMISSION ARE SUPPORTED BY THE TRANSFER CASE SKID PLATE. BEFORE REMOVING THE TRANSFER CASE SKID PLATE, ENSURE THAT THE TRANSMISSION IS PROPERLY SUPPORTED.
My 2002 Dodge Grand Caravan Sport runs really good. My issue is it stalls randomly like someone pulled a wire.…
The radiator fans ran for a while after the ignition was turned off, when it's hot. That stopped. What is…
Do you have to change all ball joints at same time? we have already replaced the drivers side rear upper.…
Replacing front shocks. What I see on the internet looks nothing like my car. On my car the shock is…
hi i have a hond accord from 1999 2l vtec engine. i have a chekengine that dous not go away.…
Is this engine an interference engine? If the manual specifies a time and mileage for the timing belt, water pump…
View Comments
I do not understand what you mean with:Tighten the bolts to 74 N·m ( 55 ft. lbs.) torque.or 28 N·m ( 21 ft. lbs.) torque.
What is N m?! actually.
N.M. stands for Newton Metre, If your torque wrench shows foot pounds(ft. lbs.) then focus on that alone.
The newton metre (also newton-metre, symbol N m or N·m) is a unit of torque (also called "moment") in the SI system. One newton metre is equal to the torque resulting from a force of one newton applied perpendicularly to the end of a moment arm that is one metre long.
Source: Wikipedia
