Home » Car Questions » Whining Noise 2006 Dodge Caravan SXT
2006 Dodge CaravanWhen I start up my 2006 Dodge Caravan SXT, it makes a whining noise. I tried driving around the block to see if it stops but the gas pedal vibrates and the noise gets louder. Not sure what is wrong. Any help would be greatly appreciated.
Usually a whining noise if from a hydraulic pump. Your vehicle has two. The transmission and the power steering. Check the fluid levels on both. Of course if one of them are low take measures to refill them. Check the transmission fluid with the engine running. Check the power steering fluid with or without the engine running.
