all at the same time my speedometer stopped working my wipers stopped oil pressure gauge reads 0 it is an automatic but will not shift gears. Changed the speed sensor no help had a mechanic check it out his computer says speed sensor but that is brand new the mechanic was stumped and so am I. I does blow a 7.5 amp fuse
There are several 7.5 amp fuses. If you could tell me number of the fuse I could pull up the appropriate wiring diagram for that circuit. You will need to locate the short in that circuit and repair it. Once the repair is made the fuse will no longer blow and the circuit will function as it should.
