Home » Car Questions » Grinding Noise 2010 Nissan Versa
2010 Nissan VersaI hit a pot hole the other day. Now my passenger tire, when I get up to about 30-40mph, is making a grinding noise until I fully stop.
Grinding Noise
Something isn’t right. You definitely need to have it looked at. Could be as simple as an air damn being bent. May be something more important suck as a brake issue. Take note whether or not the noise changes pitch when braking or turning. If the steering seems to want to pull the tire may be rubbing something. You may also be able to put the car up on jack stands and put the car in gear and look to see if you can locate the issue.
