Home » Car Questions » Noisy AC 1994 Olds 88 Royale
1994 Olds 88Air Conditioning was noisy when turned on. Eventually clutch does not engage. Do you recommend to replace clutch only or a/c kit?
I would recommend replacing the entire air conditioning compressor instead of just the clutch. The amount of labor cost makes it a wash. This way you end up with a New compressor as for the same money.
