Home » Car Questions » Timing 1998 Dodge Intrepid
2000 Dodge Intrepid3.2 i was driving then i smelled burning wire followed by the car over heating and running hot i looked under the hood found a couple spots of wire that need to be fixed and it doesn’t wasn’t to start its trying to but its just not catching someone told me timing how do i check the timing chain with out taking the whole front end apart
If you feel the timing is the issue, a quick test I use is a compression test. This lets you know a valve is open when it shouldn’t be.
