Home » Car Questions » Headlight Replacement 2009 Honda Accord
2009 Honda AccordHow do I replace the high beam lamps on my 2009 Honda Accord EX?
Headlight Replacement (High Beam)
  1. Disconnect the 2P connector (A) from the headlight wiring harness.
  2. Turn the bulb socket 45 º counterclockwise to remove the bulb.
  3. Install a new bulb in the reverse order of removal.
high beam headlight replacement 2009 Honda Accord
Headlight Replacement (Low Beam)
  1. Remove the inner fender.
  2. Disconnect the 2P connector (A) from the headlight.
  3. Turn the bulb socket 45 º counterclockwise to remove the bulb.
  4. Install a new bulb in the reverse order of removal.
headlight replacement low beam 2009 Honda Accord
