Home » Car Questions » Headlamp 2006 KIA Sportage EX
2006 KIA SportageI have a 2006 KIA Sportage and I need  the headlamp assembly removal procedure.
Headlamp Replacement 2006 KIA Sportage
Headlamp Removal Diagram 2006 KIA Sportage
Headlamp Removal
  1. Disconnect battery negative cable.
  2. Remove radiator grill cover mounting bolts.
  3. Lift radiator grill cover and pull up on headlamp mounting tab.
  4. Disconnect electrical connectors and remove headlight.
Headlamp Installation
  1. Connect electrical connectors to headlight.
  2. Install headlight push down on locking tab.
  3. Install radiator grill cover mounting bolts.
  4. Connect battery negative cable.
