Chrysler Code P0700 after used motor put in.
Chrysler Code P0700 – Transaxle Control System Malfunction
Since the P0700 is just and informative code, check the TCM for more codes to resolve the problem.
Possible causes
- Shorted or open circuit within Transmission Control Module (TCM)
- Faulty Transmission Control Module (TCM)
P0700 Chrysler Description
The transaxle Control Module (TCM) monitors the malfunction of sensors and actuators relating to transaxle control. When the TCM detects a malfunction with the control, a signal is send to the Engine Control Module (ECM) to trigger the Engine Light or Service Engine Soon light. The ECM stores the P0700 code and it means the TCM detected a malfunction with the transaxle controls.
