Power Mirrors 2001 Chevy Silverado
2001 Chevy SilveradoPower Mirrors won’t work, can’t find a fuse for it on the fuse block. Is there a in line fuse some where?
There is not an inline fuse for the mirrors. It would appear, after looking at the wiring diagram, that the mirror fuse and clock fuse are one in the same. It also powers the drivers door power windows and lock switch. So if all that is working most likely the fuse is good.
Mirror Fuse Location
The fuse is located in the Fuse Block. It is a 3 amp fuse. The label should be “MIR/CLOCK”. Look under the fuse block cover for a list of fuses and exact location.
Power Mirrors Wiring Diagram
2001-chevy-1500-power-mirror-circuit-1-of-1
