Home » Car Questions » 1998 Buick Park Avenue
Buick Park AvenueMy left turn signal is working perfectly but right isn’t
Do you see the light on the dash blinking a bit faster on the right as compared to the left? If the answer is YES, than most likely one of the bulbs is blown on the right side. Replacing the blown bulb will correct this.
Possible Causes
  • Wrong bulb
  • Loose connection at bulb
  • Bad connection in wiring
  • Rusted ground connection
  • Wiring issue
  • Worn multi-function switch
