Home » Car Questions » 2002 GMC safari transfer case
2002 GMC Safari AWDyes i was told that i could take my transfer case (that is a two wire plug-in to encoder) and use a 6 wire transfer case but just change the encoder motor on it with the one off of my… and put the two wire encode on that transfer case.. will this really work…. will the pcm still read and work right. i no it has to be able to read the pwm ,pm ,rpm,vss, and hell who no;s i don’t thats y im here asking hope some one give me some info. on this thanks gene
Since you are still using the same electronics, I don’t see any reason why it wouldn’t work. The computer won’t even know you have changed anything and should work just fine.
1 thought on “2002 GMC safari transfer case”
