Home » Car Questions » 2003 Toyota Corolla S
 Toyota CorollaI bought a wheel bearing hub assembly but its for a car with anti lock breaks and my car does not have anti lock breaks. Can I install it anyway without hooking up the abs sensor?
If it bolts up, I don’t see why not. You will want to cut or remove the wiring from the hub bearing so it is not is the way.
Typically the hub bearing without the sensor is cheaper. Exchanging the bearing might be more cost effective unless there is excessive shipping costs involved.
