My Audi A5 convertible is having random problems all at once. The top won’t open, the rear camera is fuzzy, the seats don’t move forward/backward, or lean back. I think it’s electrical but I don’t know. I’m selling the car so I don’t want to invest a lot of money into it. Thank you for your help.
Michael
Definitely electrical. Could be a bad connection or corrosion at the battery terminals. A blown fuse may also be an issue. A blown fuse is a common occurrence if the vehicle has been jump started recently. Check your battery and fuses first. If they all check out you are looking at having to trace wiring and testing each component.
