Home » Car Questions » Running Rich 1997 Ford F150 4.6 liter V8
1997 Ford F150My truck has a rough idle. After having my truck scanned at Autozone it said that my truck is running rich. What is wrong with my truck?
Running Rich
Present me with the code that Autozone told you and I will be happy to assist you further.
For now I will just guess your code.
Ford Code P1152 – Lack of Upstream Heated Oxygen Sensor Switch Sensor Indicates Rich Bank 2
Ford Code P1152 Possible causes
Ford Code P1152 FORD Description
The Heated Oxygen Sensor (HO2S) Monitor is an on-board strategy designed to monitor the HO2S sensors for a malfunction or deterioration that can affect emissions. Under specific conditions, the fuel control or upstream HO2S sensors are checked for proper output voltage and response rate (the time it takes to switch from lean to rich or rich to lean). Downstream HO2S sensors used for Catalyst Monitor are also monitored for proper output voltage. Input is required from the Engine Coolant Temperature (ECT) or Cylinder Head Temperature (CHT), Inlet Air Temperature (IAT), Mass Air Flow (MAF), Throttle Position (TP) and Crankshaft Position (CKP) sensors to activate the HO2S Monitor. The Fuel System Monitor and Misfire Detection Monitor must also have completed successfully before the HO2S Monitor is enabled.
• The HO2S sensor senses the oxygen content in the exhaust flow and outputs a voltage between zero and 1.0 volt. Lean of stoichiometric (air/fuel ratio of approximately 14.7:1 for gasoline engines), the HO2S will generate a voltage between zero and 0.45 volt. Rich of stoichiometric, the HO2S will generate a voltage between 0.45 and 1.0 volt.
  • The HO2S Monitor evaluates both the upstream (Fuel Control) and downstream (Catalyst Monitor) HO2S for proper function.
  • Once the HO2S Monitor is enabled, the upstream HO2S signal voltage amplitude and response frequency are checked. Excessive voltage is determined by comparing the HO2S signal voltage to a maximum calibratable threshold voltage.
  • A fixed frequency closed loop fuel control routine is executed and the upstream HO2S voltage amplitude and output response frequency are observed. A sample of the upstream HO2S signal is evaluated to determine if the sensor is capable of switching or has a slow response rate.
  • An HO2S heater circuit fault is determined by turning the heater on and off and looking for a corresponding change in the OSM and by measuring the current going through the heater circuit.
  • The MIL is activated after a fault is detected on two consecutive OBD II drive cycles.
