Home » Car Questions » Window Motor 2004 Mercury Monterey
2004 Mercury MontereyThe passenger window will not go up or down. It worked off and on for a while but now it stopped. It does not work from either door rocker switch (driver / passenger)
Window Motor Failure
You will need to have the window motor and regulator assembly replaced. They come together as one component. I have found trying to replace them separately ends up being more of a hassle. It also take more time.
Window Motor Replacement
  1. Remove the front door trim panel.
  2. Position the watershield aside.
  3. Remove the parts int he order indicated in the following illustration and table.
window motor replacement diagram
1 thought on “Window Motor 2004 Mercury Monterey”
