Home » Car Questions » How to Adjust Transmission Bands
adjust transmission bands
How do you adjust transmission bands?
Since the band adjuster has a lock-nut it will need to be removed. You will need two wrenches in order to loosen the lock-nut from the band adjuster. Loosen the lock nut off about 4 turns. Now you are able to adjust the band. Spray a bit of WD-40 on the band adjuster to make it easier to turn. Once adjusted make certain to tighten the lock-nut. Repeat on additional bands if needed.
Hydra-Matic Transmission Band Adjustment
Not all transmissions have band adjustments. No band adjustments are necessary or possible on Turbo Hydra-Matic transmissions; they use clutches instead of bands.
Ford C-6 Only Intermediate Band Adjustment
  1. Raise the truck on a hoist or jackstands.
  2. Clean all dirt away from the band adjusting screw. Remove and discard the locknut.
  3. Install a new locknut and tighten the adjusting screw to 10 ft. lbs. (13 Nm).
  4. Back off the adjusting screw exactly 1 1 ⁄ 2 turns.
  5. Hold the adjusting screw from turning and tighten the locknut to 35–40 ft. lbs. (47–54 Nm).
  6. Remove the jackstands and lower the vehicle.
Automatic Transmission Band Adjustments
GENERAL MOTORS
TransmissionLow Band
PowerglideTighten to 72 in/lbs,
Back Off 4 Turns Counterclockwise
 *No external band adjustments on TH350, TH400, 2004R, 700R4.
FORD
TransmissionIntermediate Band
C6Tighten to 120 in/lbs
TransmissionIntermediate Band Low-Reverse Band
C4Tighten to 120 in/lbs,
Back Off 1 3/4 Turns Counterclockwise
Back Off 3 Turns Counterclockwise
C4 w/ Trans-Brake Tighten to 120 in/lbs,
Back Off 1 1/2 Turns Counterclockwise
Back Off 2 Turns Counterclockwise
 *No external band adjustments on AOD.
CHRYSLER
904 StreetFighter®
Single Wrap Band: Tighten 72 in/lbs,
Back Off 3 1/4 Turns Counterclockwise
Double Wrap Band: Tighten 72 in/lbs,
727 StreetFighter®Tighten to 72 in/lbs,
Back Off 2 1/2 Turns Counterclockwise
904, Full ManualTighten to 72 in/lbs,
727, Full ManualTighten to 72 in/lbs,
904 w/ Trans-BrakeTighten to 120 in/lbs,
727 w/ Trans-BrakeTighten to 120 in/lbs,
