Home » Car Questions » AC Drain 2009-2010 Chevy Malibu
2011 Chevy Malibuwhere is AC drain and how to clear it ?
AC Drain
The AC Drain should be located at the lower portion of the HVAC assembly. It may be easier to see from underneath the car. look under the firewall area under the heater hoses, etc. Simply insert the end of a screw driver in the bottom and wiggle. Any debree will fall out and allow any moisture to drain.
