I’m in need of the wiring diagram for the fog lights from the bulbs to the switch. I am adding factory OEM fog lights and will be replacing the switch with the fog light button so everything looks like it came factory installed. Thank you.
There is no direct connection between the fog light switch and the outside world. The BCM reads the resistance from the light switch and then determines what has to happen as far as turning on and off certain outputs. I’m not sure of the BCM is wired to the outside world or not. My guess would be no.
