Home » Car Questions » 1967 Camaro short at the fusible link
1967 Chevy CamaroShort at the fusible link
I had a short at the fusible link. Now I don’t have low beams. have high beams. changed light switch, and 2 new headlights. still nothing
My first thought would be is did you fix the short? You have a loss of power on the low beam wire. Use a multi-meter and check for continuity on that wire.
