2003 Chrysler pt cruiser shutting down
2003 Chrysler Pt CruiserThe car will just shut down while I’m driving. A few weeks my mechanic replaced the transmission sensor. Now it’s just shutting down ever thing cuts off. After a few minutes it usually will start up again. I am not driving it now
Car Shutting Down
Intermittent problems can be frustrating and time consuming. When the car is running fine and starting fine all tests performed will usually come back as showing no errors with anything.  Knowing that, all diagnostic testing will need to be carried out while the problem is present. So only diagnosing when the vehicle will not start will lead us the cause of the problem.
This may require leaving the vehicle with a mechanic for a long stay.
