Replace Air Conditioning Condenser
How long does it take to remove and replace the air conditioning condenser? I was a mechanic for 9 years. And I understand that I will need to take the car to garage to get the gas refilled.
I do not currently have access to that information. Is the Seat Ibiza similar to any other vehicles? This might allow me to cross reference them?
On other compact cars it typically takes around 2 hours. Does include front bumper cover removal. Does not include the recharge time.
Air Conditioning Condenser Replacement
- Recover the refrigerant.
- Remove the air cleaner assembly.
- Disconnect the radiator inlet and outlet hoses from the radiator.
- Remove the engine coolant fan.
1. Air Conditioning Compressor and Condenser Hose Nut (Qty: 1)
Procedure
Disconnect the air conditioning compressor and condenser hose from the A/C condenser.
Tighten: 10 Y (89 lb in)
2. Air Conditioning Evaporator Hose Assembly Nut to Air Conditioning Condenser (Qty: 1)
Procedure
Disconnect the air conditioning evaporator hose assembly from the A/C condenser.
3. Radiator Support Mounting Bolt (Qty: 4)
Tip: Rotate the radiator support to tilt the radiator when removing the condenser.
Tighten: 22 Y (16 lb ft)
4. Air Conditioning Condenser
