Home » Car Questions » Jeep Cherokee buzzing humming sound
1995 Jeep Grand Cherokee Laredo
Buzzing\humming sound
Buzzing\humming sound out of drivers rear tire. Brakes replaced, rotors also. Its the same idle and or driving. A constant sound. What would cause this?
If the noise wasn’t there before your last repair, I would recommend checking the last thing worked on first. If you are just looking for what else it could be besides the brakes then I would suggest checking the outer axle bearings.
Axle Shaft Bearing Replacement 1995 Jeep Cherokee
1995-jeep-cherokee-axle-shaft-bearing-and-seal-removal-and-installation
