Starves for gas intermittently
My Jeep seems to starve for gas intermittently. What is wrong with it? thanks for the reply …..
It could be that it is starved for gas. The fuel filter may be clogged. The fuel pressure regulator may be faulty. The MAF sensor may be dirty and sending bad readings. The fuel pump may be weak causing low fuel pressure. Finally even the gas tank may be low since it is acting like it is starving for gas.
What First
Start by pulling any check engine light codes. Post the codes in the comments for more information on the codes and how to go about diagnosing each code.
