Home » Car Questions » Window Motor 2002 Dodge Dakota 4 door pickup
Dodge DakotaHow to remove and replace driver side front door window motor and assembly?
Window Motor Removal
The power window motor and mechanism is integral to the power window regulator unit. If the power window motor or mechanism is faulty or damaged, the entire power window regulator unit must be replaced.
Window Regulator Removal
1.Remove glass from door.
2.Disengage power window motor wire connector from door harness, if equipped (POWER REGULATOR).
window regulator1 – SCREW
2 – SCREW
3 – POWER WINDOW REGULATOR
3.Loosen bolts in slotted holes attaching regulator to door inner panel (POWER REGULATOR BOLTS).
window motor regulator1 – REMOVE BOLTS
2 – LOOSEN BOLTS
3 – DOOR INNER PANEL
4.Remove bolts attaching window regulator to inner door panel.
5.Extract window regulator through access hole in inner door panel.
