Home » Car Questions » Dodge Code P2190 on dash 2007 Dodge Sprinter
2006 Dodge SprinterI get a 219d code on the dash when I start the vehicle. It disappears after about 1 minute. I have a diesel. Do you know what it means.
Dodge Code P2190 – Bank 1 AFR imbalance
The engine control module (ECM) controls the air/fuel metering system in order to provide the best possible combination of driveability, fuel economy, and emission control. Fuel delivery is controlled differently during Open Loop and Closed Loop. During Open Loop, the ECM determines fuel delivery based on sensor signals without heated oxygen sensor (HO2S) input. During Closed Loop, the ECM adds HO2S inputs to calculate the short and long term fuel trim (FT) adjustments. If the HO2S indicates a lean condition, the fuel trim values will be above 0 percent. If the HO2S indicates a rich condition, the FT values will be below 0 percent. The short term FT values change rapidly in response to the HO2S voltage signals. The long term FT makes coarse adjustments in order to maintain an air/fuel ratio of 14.7:1.
Code P2190 Possible causes
•Leaking fuel injector or pressure regulator
•High fuel pressure condition
•Faulty Oxygen (O2) Sensor
•Faulty Mass Air Flow (MAF) sensor
