Home » Car Questions » No spark 2003 escape 3.0
2003 Ford Escape
No spark
No spark. My camshaft position sensor and crankshaft position sensor are good. I test no power at coil packs. I checked fuses and  not sure how to proceed from here.
According to the chart it would appear the next step would be to look at the ignition system wiring, voltage regulator.
The PCM controls sends the voltage to the ignition coils. Maybe the signal wires from the sensors or the wires coming from the PCM or the PCM itself.
Ignition Coil Wiring Diagram 2003 Ford Escape
2003-ford-escape-engine-controls-1-of-4
