Home » Car Questions » 2000 saturn ls2
2000 saturn ls2
2000 Saturn Ls
The engine turns on in the start position. 12 volts stays on to the starter instead of run. Had replaced ignition switch and remains the same. Is the problem on the TR switch or the ignition lock housing?
Maybe some faulty wiring or bad connections. Use the provided wiring diagram to help assist in checking the wiring.
2000-saturn-ls2-starting-circuit-1-of-1
