Home » Car Questions » 2004 Hyundi Tiburon Gt turn signals
2004 Hyundai Tiburon
Won’t go in drive when fuse replaced for signal lights when fuse taken out car goes in drive. Has to pass inspection to get tags please help
Seems odd that you would know just what fuse to take out. My guess would be there has been some aftermarket radio or gadget installed improperly. If this is not the case and the fuse was being replaced because it was blown, then you need to fix what ever caused the fuse to blow in the first place. I will provide you with a wiring diagram to help assist you with just that.
Turn signal wiring diagram
2004-hyundai-tiburon-exterior-lights-exterior-lamps-circuit-1-of-1
