I need a ignition switch replacement diagram for the above car. please email it to me to:
XXXXXXXXXXXXXXX@outlook.com
Ignition Switch Removal
1. ALIGN FRONT WHEELS STRAIGHT AHEAD
2. DISCONNECT CABLE FROM NEGATIVE BATTERY TERMINAL
CAUTION:
Wait at least 90 seconds after disconnecting the cable from the negative (-) battery terminal to disable the SRS system.
3. REMOVE LOWER NO. 3 STEERING WHEEL COVER
4. REMOVE LOWER NO. 2 STEERING WHEEL COVER
5. REMOVE STEERING PAD
6. REMOVE STEERING WHEEL ASSEMBLY
7. REMOVE LOWER STEERING COLUMN COVER
8. REMOVE UPPER STEERING COLUMN COVER
9. REMOVE IGNITION SWITCH ASSEMBLY
Ignition Switch Installation
- Install in reverse order
