Code P0353 and Code P1000
Here’s what I have so far from chasing the rabbit down the hole…
- New Autolite Platinum plugs gapped .042
- <2000 miles on Duralast plug wires
- New BWD ignition coil pack (twice)
- Installed New cats y-pipe with 3rd (Unmonitored) deleted
- New Bank 2 Sen 1&2 O2 sensors
- New Heated PCV
- Vacuum runs 19-21.4 at idle. Drops to 0.5-1.0 on take off then to around 12 to maintain on flat ground.
- Idle in park fluctuates between 650-750rpm
- Replaced vacuum line & coupler on the backside of the air intake tube behind the MAF.
- Ran the smoke/propane/water mist tests, no leaks
- Barely gets up a small hill going 20 with about 50% throttle. All the while stuttering like it has a bad plug
- Alt & Batt tested good
- Belt and tensioner good
Shows codes P0353(intermittently) & P1000 (constant, no CEL)
The P1000 is showing up because the vehicle has not under gone the drive cycle required after all codes are cleared. This is normal when working on clearing codes and testing. Once you have repaired the Code P0353 the drive cycle procedure can be performed to remove the Code P1000. This helps to prevent drivers from trying to game the system by just clearing the codes before an emissions test. I have added the drive cycle information below.
Review the possible causes for code P0353. Use this information to assist in diagnosing the problem.
Ford Code P0353
DTC Code: | P0355 |
Description: Ignition Coil C Primary/Secondary Circuit Malfunction | |
Probable Causes: |
Ford Code P1000
DTC Code: | P1000 |
Description: OBD II Monitor Test/Drive Cycle Not Complete | |
Probable Causes: |
Evaporative Emission Repair Verification Drive Cycle
Special Tool(s)
Worldwide Diagnostic System (WDS)
Vehicle Communication Module (VCM) with appropriate adapters, or equivalent diagnostic scan tool
Drive Cycle Recommendations
NOTE: The following procedure is designed to execute and complete the evaporative emission repair verification drive cycle and to clear the Ford P1000, inspection and maintenance (I/M) readiness code. When the ambient air temperature is below 4.4°C (40°F) or above 37.8°C (100°F), or the altitude is above 2,438 meters (8,000 feet), the EVAP monitor will not run. If the P1000 must be cleared in these conditions, the powertrain control module (PCM) must detect them once (twice on some applications) before the EVAP monitor can be bypassed and the P1000 cleared. The EVAP bypassing procedure is described in the following drive cycle.
1. Most OBD II monitors will complete more readily using a steady foot driving style during cruise or acceleration modes. Operating the throttle in a smooth fashion will minimize the time necessary for monitor completion.
2. Fuel tank level should be between 1/2 and 3/4 full with 3/4 full being the most desirable.
3. The evaporative monitor can only operate during the first 30 minutes of engine operation. When executing the procedure for this monitor, stay in part throttle mode and drive in a smooth fashion to minimize fuel slosh.
Drive Cycle Preparation
NOTE: For best results, follow each of the following steps as accurately as possible.
4. NOTE: This step bypasses the engine soak timer and resets OBD II monitor status.
Install the diagnostic tool. Turn the key ON with the engine OFF. Cycle the key OFF, then ON. Select the appropriate vehicle and engine qualifier. Clear all diagnostic trouble codes (DTCs) and carry out a PCM reset.
5. Begin to monitor the following PIDs: ECT, EVAPDC, FLI (if available) and TP MODE. Press Diagnostic Data Link, PCM, PID/Data monitor and record, press trigger to select each PID, then start.
6. Start the engine without returning the key to the OFF position.
Preparation for Monitor Entry
WARNING: Strict observance of posted speed limits and attention to driving conditions are mandatory when proceeding through the following drive cycle.
7. NOTE: This step allows engine warm-up and provides intake air temperature (IAT) input to the PCM.
Idle the vehicle for 15 seconds. Drive at 64 km/h (40 mph) until the engine coolant temperature (ECT) is at least 76.7°C (170°F).
8. Is IAT above 4.4°C (40°F) and below 37.8°C (100°F)? If not, continue with the following steps but note that the EVAP Monitor Bypass portion of the drive cycle (Step 13) will be required to bypass the EVAP monitor and clear the P1000.
9. NOTE: This step executes the heated oxygen sensor (HO2S) monitor.
Cruise at 64 km/h (40 mph) for 60 seconds.
10. This executes the EVAP monitor if IAT is above 4.4°C (40°F) and below 37.8°C (100°F).
NOTE: To initiate the monitor, TP MODE should equal PT, EVAPDC must be greater than 75 percent, and FLI must be between 15 and 85 percent.
NOTE: Avoid sharp turns and hills.
Cruise at 72 to 104 km/h (45 to 65 mph) for 10 minutes.
11. NOTE: This step executes the ISC portion of the Secondary Air/CCM.
Bring the vehicle to a stop. Idle with the transmission in DRIVE (for automatic transmission) or NEUTRAL (for manual transmission) for 2 minutes.
Pending Code and EVAP Monitor Bypass Check
12. NOTE: This determines if a pending code is preventing the clearing of Code P1000.
NOTE: If the EVAP monitor is not complete and IAT was below 4.4°C (40°F) or above 37.8°C (100°F) temperature range in Step 8, or the altitude is above 2,438 meters (8,000 feet), the EVAP Monitor Bypass (Step 13) must be carried out.
Using the diagnostic tool, check for pending codes. Conduct normal repair procedures for any pending code concerns. Rerun any incomplete monitor.
EVAP Monitor Bypass
13. NOTE: This allows the bypass counter to increment to 2.
NOTE: Do not repeat Step 4.
Park the vehicle for a minimum of 8 hours. Repeat Steps 5 through 12.
