Hello, Dinamique yesterday I was doing Mot for my car Renault Laguna 200Dynamique and its fall. the mechanic says its abs pump fault and you need it to change. But how he knows it’s a abs pump, not fuses or leads? Thank you
ABS light is on
I’m sure he tested those. The good news is as long as the ABS light is on, the ABS just won’t work. This means you can continue to drive it only to remember that the wheels can lock up when you slam on the brakes just like the cars did back in the 70’s. You can drive it like this as long as you like.
