Home » Car Questions » 2002 f250 lariet crew cab v 10
2002 Ford F250
Hi, I have a 2002 f250 V10 crew cab. When I go over rough road the front end can pull and move me over in the lane. The front end has been checked and new shocks installed but it still does it and when I Hit freeway bumps it hits real hard. If I install air bags in the coil springs will it help the ride and steering?
Air bags are not going to help the ride or the steering. It would make the ride stiffer. I would have the tires and alignment checked. Also check for a loose steering gear box. If your tires are oversized (not stock size) this may also cause the vehicle to want to shoot to one side of the road or the other.
