Home » Car Questions » 2008 Toyota Yaris turn signal switch
2008 Toyota Yaris
What does it take to repair a right turn signal that won’t self-cancel?
Turn Signal Switch Removal
Replacing the combination switch assembly will be required. This will require the removal of the steering wheel pad and wheel. Then removing the upper and lower column covers.
steering wheel removal 2008 Toyota Yaris
  • Disengage the clamp indicated by the arrow in the illustration.
  • Remove the turn signal switch assembly with spiral cable from the steering column assembly.
turn signal removal diagram 2008 Toyota Yaris
