Home » Car Questions » 2012 Chevy Equinox catalytic converter
Chevy Equinox
My catalytic converter has melted so says the garage.
Was there a question in there? The converter typically melts internally if there is un-burnt fuel exposed to it during operation. For example, if one of the cylinders of the engine was not firing and allows the fuel to simply pass through. When this happens there is usually a rotten egg smell that accompanies the situation.
Catalytic Converter Replacement (FWD)
catalytic converter 2012 Chevy Equinox
1Exhaust Manifold Nut (Qty: 3)
Caution: Refer to Fastener Caution.
Tighten
50 Y (37 lb ft)
2Exhaust Muffler Nut (Qty: 2)
Tighten
40 Y (30 lb ft)
3Catalytic Converter Bracket Clamp Nut
Tighten
50 Y (37 lb ft)
4Exhaust Insulator Hanger
5Seal
6Gasket
7Catalytic Converter
Tip: Replace with NEW gasket and seal.
