2004 Chrysler Concorde 2.7 recently developed code p0700 a general tranny code and p1779 solenoid switch in the l/r position. Did some looking and found a bare wire on either the speed input sensor or output sensor. Not sure what on. I fixed the problem and now the cruise control works as well. Could that have caused the tranny codes?
Yes.
Chrysler Code P0700
Transmission Control System (Malfunction Indicator Lamp Request)
Code P0700 Probable Causes
- Sensor or solenoid faulty
- Update control unit software – Check for the latest control unit update
- Powertrain or Engine Control Module faulty
- Transmission system malfunction
Generic Code P1779
Engine Torque Delivered to TCM Signal
Code P1779 Probable Causes
- Connector terminal contact is damaged or corroded
- Wire harness – Check harness for correct voltage, open, short to ground or short to voltage
