Home » Car Questions » 05 Dodge Ram cylinder that keeps filling with water
2005 Dodge Ram 1500
Keeps overheating. Cracked a head but put that feeling in it and it seem to fix it. It started overheating again and I replaced the radiator hoses and thermostat. I am still losing water but can’t find out from where exactly. I have a cylinder that keeps filling with water. What’s my next option?
Cylinder that keeps filling with water
Remove the cylinder head that is effected and have it checked for cracks. It may just be a blown head gasket. This will be apparent once the head is removed. The only other way for coolant to get into a cylinder would be a crack in the intake and or intake gasket. This is not as common as the head issue. The engine will overheat until the leak is repaired.
