I need a vacuum diagram for this car. Can you help? email me a diagram please!!
Engine Vacuum
Pcv and Brake booster go to separate large ports, the pcv usually to the carb base and the booster to the manifold fitting.
Vacuum advance goes to one of two small ports on the carb. Test to find the one that has no vac at idle but as soon as you touch the throttle you get vacuum.
Cruise goes to either the small port on the intake or the carb base. It could be split off the vacuum advance.
1973 Dodge Charger Vacuum Diagram
1973 Dodge Charger Vacuum Ports Diagram
