Blower motor stopped working
The blower motor stopped working. I’ve replaced the resister and it’s still not working any suggestions? It is a 2001 Chevy Impala 3.8 series 2.
- Check the 4 fuses that are used in the blower motor circuit.
- A/C Cruise Fuse10A
- A/C BLO Fuse(blower) 20A
- DIC/RKE Fuse10A
- A/C BLO Fuse 25A.
The fuses are located in the inside fuse panel. You may use the wiring diagram to gain a better idea of how the circuit works.
- Test the blower motor itself. Apply battery positive and negative to the blower directly. I use a power probe to do this. The tool allows you to connect a good ground. And apply battery positive with the touch of a button.
Blower Motor Wiring Diagram – 2001 Chevy Impala
(best viewed using Google Chrome or Firefox)
2001-chevy-impala-air-conditioning-manual-a-c-circuit-1-of-1
