Home » Car Questions » Both headlights have stopped working 2013 Chrysler 200 LX 2.4l
2013 Chrysler 200
Headlights stopped working
If you know both were working then I would start with checking the fuses. If one was out and now both, start with replacing the headlights. There are 3 fuses to check. Check fuse #33, #17 and #12. Once you confirm the fuses are good, test for power and ground at the headlights.
Good power and ground means replace the headlamps. Still now power, check the multi-function switch. If that checks out then you are left with the Power module or wiring. I’ll supply you with a wiring diagram to help assist you with the problem.
Headlight wiring diagram – 2013 Chrysler 200
(best viewed with Google Chrome or Firefox)
2013-chrysler-200-color-schematics-headlights-1-of-1
2 thoughts on “Both headlights have stopped working 2013 Chrysler 200 LX 2.4l”
  1. What fuse should I change for the license plate? I already change the bulls and still not working. Chrysler 200 2013.
