What do DTC # P0301, 0304, 0500 and 0501 mean?
P0301 is a misfire code for cylinder #1 and P0304 is a misfire code for cylinder #4
Code P0301 and P0304 Probable Causes
- Update control unit software – Check for the latest control unit update
- Powertrain or Engine Control Module faulty
- Fuel injector(s) faulty
- Ignition system – Ignition module, coil, spark plugs and wires
- Fuel system
Hyundai Code P0500 – Vehicle Speed Sensor A
Code P0500 Probable Causes
- Sensor or solenoid faulty
- Connector terminal contact is damaged or corroded
- Wire harness – Check harness for correct voltage, open, short to ground or short to voltage
Hyundai Code P0501 – Vehicle Speed Sensor A Range/Performance
Code P0501 Probable Causes
You Have a bad coil pack and its very easy to replace yourself.
