Home » Car Questions » ABS and Brake light on 2008 Dodge Caravan
2008 Dodge Grand Caravan
I have a dodge caravan 2008 and my ABS light along with brake light,what can i do and what is the sense of urgency.
When this occurs while driving under normal conditions it is caused by the brake fluid level being slightly low. Topping off the brake fluid level should allow the function to restore. However an inspection of the brakes should be performed in the next few weeks or so.
The brake system is a closed system. This means that unless the brakes pads wear down or there is a leak, fluid does not need to be added.
If the roads are icy or snowy then the lights may come on when the system is activated. Once the car is turned off and restarted the light may go out. If the the lights continue to stay on, an inspection is advised.
